how about Rane twelve support?
how about Rane twelve support? I would love something with a rotating platter since you don’t support ant vinyl timecode. I guess you could not map the platter stuff by yourself
thank you for your reply. Unfortunately the Race Twelve is not natively supported by djay Pro.
We value your feedback and want to thank you for sharing your needs and desires.
We are not supporting motorized platters at the moment.
Therefore, we are not supporting the Rane Twelve at the moment.
Can we map the rane 12 on djay pro?
I like the software but not compatible with dvs and turntables or phase and rane 12 is a huge limitation. I’d rather not have use Serato, but I am forced to.
