How can config and switch in DVS/INT mode on 4 decks mode?
Device model: Macbook Pro M2 16GB
Version of operating system: Sonoma 14.6.1
Version of djay: 5.2.4 for MAC
Hardware/controllers used: Pair of Reloop RP-8000 mk2, Reloop elite mixer
My idea is to make quick mixes in DVS mode or switch between DVS/INT mode in 4 decks, example:
Deck 1: Instumental 1
Deck 2: Acapella 1
Deck 3: instrumental 2
Deck 4: Acapella 2
How can configure my hardware and software to be able to quickly switch between decks. Basically what i want to accomplish is to quick switch between decks 1-4, INT/DVS mode.
Example:
Step1. Start playing Instumental 1 in Deck 1 (REL mode)
Step2. Scratch Acapella 1 in Deck2 (REL mode)
Step3. Switch to Deck 4 (INT mode) in Reloop Elite, Play Acapella 2
Step4. Switch Deck 1 to INT mode, Start playing Instumental 2 in Deck 4 in (REL mode)
My DVS configuration is the default:
Deck 1: Reloop ELITE ch 1-2
Deck 2: Reloop ELITE ch 3-4
I don’t know what kind of configuration i have to do?
Hi @Kutzilla_DJ, if I understand correctly you want to switch the two physical turntables between the four virtual ones? You would have to do that in djay’s DVS settings.
