In djay (original) I could bring up the ‘skipping’ controls where the loop controls are located (in djay pro). I cannot seem to find skipping control anywhere except for in the ‘deck 1’ drop down menu => ‘skipping.’
Anyone know what’s up?
I’ve added a picture of the skip control being activated in djay.
As far as I understand - it is only possible to map something to skip one measure (no way to skip half or two measures, etc). If I am wrong please enlighten me!!
The Skipping buttons are no more available in the Main Screen of djay Pro, as we wanted to prevent the djay Pro interface from becoming overload with controls. However, you can still use the Keyboard Shortcuts “3” and “4” to skip through your tracks. Hopefully you can get along with that.
Skip, 1 beat, 2, 4, 6, 8, 16, 32, are available as well. I set mine to 4 beats on a endless rotary so I can fast forward or reverse through a song. The rotary also has indents during rotation so if I need to extend a section, I rotate reverse 1 click and the beat and phrasing stays in time for each click.
