How do I get rid of the delay with the crossfader?
Hi @Justin_Rudolph,
To get a better understanding of your issue could you please answer the following:
- Which iOS device are you using?
- What version of iOS are you running?
- What version of djay are you running?
- Are you using a controller with your iOS device?
- Can this “delay” be considered general lag in which the crossfader does not immediately move with your finger or to the speed of your physical controller’s crossfader?
