Hi, thanks for the reply
I know this feature but I need to save the playlist I do with iDJ as well and read it in itunes.
Plus it would be nice to be able to rate the music directly in iDJ and see it in itunes.
And last request would be able to project the music info in the video output
best regards
vasco
Hi Vasco Martins,
playlists are synchronised right from your iTunes/ Spotify. So every playlist you set up in iTunes/Spotify will synchronise automatically.
thank you for your feedback.
I processed your request internally and we want to thank you for your idea of projecting the music info in the video output.
