I’m using DJ Pro with Spotify and I do see my playlists but cannot find music by looking at my saved albums. Is that possible?
Thanks,
Thanks,
Hi Paulo,
where are you checking for your saved albums?
we are not able to show your saved albums as the integration is not allowing it.
Please save the whole album as Spotify Playlist, that way it will be shown in djay.
I’m checking on the Spotify integrated library, where I can see the playlists but not saved albums as I see on my Spotify. That would be so useful…
I came here looking for the same answer. At best the library on spotify through the dj pro app shows all songs. From there even with using filters, I haven’t found a way to view my library’s different albums without seeing duplicates of each album for each song to that specific album. If that makes sense.
Is there a way to view my spotify albums…one at a time?
Please reply with a solution. Cheers.
