I’m using the latest version of Djay Pro. Can you tell me how to add comments to the tracks inside Djay Pro?
Thanks.
Thanks.
Hi @Noah1, it’s not currently possible to edit the metadata of songs within djay. You can, however, do this in the iTunes/Music app then resync your library.
Also, there is an existing topic to add this ability to djay if you would like to cast your vote there to show support for adding this feature to djay.
Again any update please, this seems so simple and required by many……
Please add text field for comment or rating / play order
I’m in the same camp with others- saying that ultimately I’m considering canceling my subscription, owing to the fact that classifying songs in this way through comments and ratings is crucial. We are literally begging.
Thanks for continuing to push this topic @Neil_Cooper and @Noah1. We don’t have any updates to share at this time, but I will pass your comments onto the dev team. Thanks!
Hi, I Talked with friends who use Djay but don’t take part to the community, honestly, this is so useful and basic to be allowed to put a comment on our own tracks. Please do something
Hi @Christine_Dm, welcome to the Community! Thanks for the additional feedback. I will share this with the dev team.
Hello,
Yes it’s very usefull to add comments to a track: ” nice i tro", “groovy bass”, “hypnotic melody” etc etc
Is it something very technical to had this feature to djay?
In “My collection” either right click a track and select show info or click the bottom right hand symbol on the screen
Thanks for sharing @daniel_curley
