I’m using Djay Pro on Windows with Spotify and it’s great piece of software. My only question is how do I back up my cue points and whatnot so that when I transfer computers I don’t lose it all?
Thanks in advance
Thanks in advance
On app store version cue points are backed up automatically via iCloud and all you need do is sign into your proper Apple ID on any future machines which will be used to transfer the cue points.
I had the same question some months ago…I solved with a backup of these folders “Library” “Preferences” in:
C:\Users\YourUser\AppData\Local\Packages*******.djayPro_*********\LocalState
I’m on Windows though so I don’t think I’ll get the Apple benefits. Antonio’s answer seems like the best bet for me!
