I need help changing my username. Do I need to email support?
Hi @Jamescrush,
- Simply click on your username within any existing topic
- Then click on it again at the top the pop-up screen.
- Then select the Settings cog at the far right and you can edit your username
@Slak_Jaw looks like it’s an admin-only option.
If regular users go to https://community.algoriddim.com/my/preferences/account there is no edit option:
You might need to change the Discourse username_change_period setting to a value other than 0 ![]()
Thanks @TheSouthernDJ
Hi again @Jamescrush, looks like this is only available to admins. Just let me know what you’d like to change it to and I can do it for you.
@jamescrush would be awesome. Thanks!
No problem @Jamescrush. Done!
You’re welcome!
