I want to know how to change the brake speed on DJ Pro for Mac. Bear in mind, this is not the same as the Play/Pause start/stop time. This is the one which has a default shortcut of Option + Command + 1 or Deck 1 and it is like turning the power off to a deck so it slows down slowly over a number of seconds.
I want to change this value but if I go to Settings I can only change the start/stop time when I use the Play/Pause button
Hi @Sparkomatic, there are no settings in djay for controlling the brake speed. You can only adjust the Play/Pause start/stop time.
