How do I reset the green played track indicator when browsing the library in djay for iOS?
It’s useful that djay shows which tracks have already been played in the current session. But in the next session I’d like to start from scratch (ha ha). Is there a secret trick to resetting those played indicators?
The 3 dashed lines are songs added to queue. +1 on the reset.
Okay so there are two indicators for Spotify tracks, a green check mark which is the played indicator, and which I think maybe does get created if you start a new session. And then there’s a green bar which means… something? Maybe that the track has been downloaded to the device (not that it helps if you’re offline). Anybody know what this green bar means?
Thank you for the reset feature request.
Forwarded this internally.
