I have my two XDJ 1000s and my DJM 850 connected up via usb to my mac. All three units are recognised by DJAY however the program only seems to receive signals from the DJM 850. None of the buttons or the jog wheels on the XDJs register in DJAY. Any ideas?
What about the 1000s mk2 supported or not ?
Did you already map the controllers? Open “Configure” from the “MIDI” menu to start mapping your controller.
Hi djtwok,
unfortunately the CDJ 1000s mk2 aren’t supported natively.
You can find all supported CDJs right here:
https://www.algoriddim.com/hardware
