In order to set up djay 2 with the Pioneer Wego 2,
- Connect the controller to the iPhone by using the iOS cable
- Plug in a power supply by using the USB port
No, I’m sorry, but djay doesn’t support soundcloud.
Thanks Adrian its sorted now it was a case of not having the arrow on the ios cable the right way round
Hello Adrian is it possible to use the songs from my soundcloud from the iPhone 6plus through the wego2?
Okay I’ve got it all sorted now with djay now
Hi
I just tried connecting Pioneer Wego 2 to my iPhone 6 plus (dj2 installed). Unfortunately, the app doesn’t pick up the Wego 2 connection. Any pointers? Thanks.
