How do we "mix now" while in automix mode?
I use automix mode for wedding ceremonies. How do I mix now when it automix mode?
Hi Scott,
Sorry, not quite sure what you mean by “mix now”?
Generally speaking, you can always override Automix and mix manually.
Just click on the left or right arrow to trigger the transition. Or you can manually drag the crossfader to the other side.
Understood… if a song in automix is playing and you need to go to the next song right now, how is that done without stopping automix?
Is there a way to mix to the next track right now?
PERFECT! Thank you. Will try this when I get home.
Adding a song to queue while in automix will make that song play next in the automix, then it automatically goes back to whatever playlist you were in
