I’m not a dj, but I’m trying to use this app when learning to play new songs on guitar to change the tempo. It works great, just I can’t figure out how to change the BPM by more than 10 percent. Is there a way to do this?
Hey Evan Quigley,
thank you for your post.
If you (only) want to change the pitch by more than 10%, please open the djay Settings, click General and select Range,
now you can increase the Pitch Range up to 75%.
I hope this is helping.
Cheers,Lukas E.
I believe you can do this by first dropping tempo to -5%-10% etc. . Then tap the bpm to open the bpm/tap function. Increase bpm by tapping the button as needed. Next, push the tempo back up, then press restore the bpm button and then decrease tempo as you want.
omg-thank you
