how do you change performance pad modes in djay pro windows. Controller: ddj 200 pioneer
how do you choose what your performance pads do, like how do you select between hot cue, samples , or loops modes for the pads.
Hi @charan_palanki, welcome to the community.
  1. The Pioneer DDJ-200 does not have different Performance Pad Mode buttons like most other DJ controllers, so you cannot change modes between Hot Cue, Samples, Loops, etc… You only have 8 Performance Pads per deck.
  2. However, it is possible to modify the default MIDI Mapping for the 8 Performance Pads to whatever you like within djay’s MIDI Learn Tool.
  3. Here’s a How-To-Guide for Windows: https://help.algoriddim.com/hc/en-us/articles/360014911931-How-do-I-configure-a-MIDI-controller-using-MIDI-Learn-on-djay-Pro-for-Windows-
