I exported my recording to iTunes through file sharing, but now want to convert it to an mp3. The extension of the recording is .aif…does anyone know how to convert the djay file into an mp3 after exporting?
Hi Burt,
You can convert the songs using iTunes: http://support.apple.com/kb/ht1550
exactly, itunes allows you to convert files to any one of the file types they support.
Want to convert iTunes M4P to MP3 and Play M4P Music on Samsung Galaxy S8/S7/S6/Note 8/Note 5 and other Android devices without Apple Music app? Finding the best M4P DRM Removal software to remove DRM protected from M4P DRM protect? If you want to remove the DRM from iTunes Apple Music that you downloaded from Apple Music store on iTunes for playing on any devices,the Apple Music to MP3 Converter can help you.
If you are using Apple Music subscription service, or meeting the same trouble being restricted to enjoy your offline Apple Music songs freely, you have to unlock DRM from M4P first.However,how to remove DRM from Apple Music and convert as MP3?
Apple Music Converter - Apple Music DRM removal software, or M4P to MP3 converter could help us remove DRM from M4P files, and convert M4P to DRM free MP3 format for freely enjoying. What’s more,the Apple Music Converter also can help you remove Apple Music DRM and ouput DRM-free MP3, M4A, etc.and play M4P files on Android phones and tablets, MP3 players, PSP that didn’t come from Apple and can’t run iTunes.
Hello,the iTunes music is protected in M4P format,to convert a recording into an mp3,you can use a iTunes Music to MP3 Converter.What’s more,you can use this program remove DRM from iTunes music and enjoy on any devices.
Here,learn the guide: How to Convert iTunes Music to MP3
To convert the recording to MP3, you are suggested to try Joyoshare Video Converter, it’s able to convert between up to 150 media formats. Or if you are looking for a solution to convert your iTunes or Apple Music songs to MP3, you may use TunesKit Apple Music Converter.
