Title pretty much says it all.
Wondering how well DDJ-SB2 works with Djay Algoriddm.
Any replies, much obliged
thank you for your post.
The SB 2 has two effect sections above each jogwheel which can be used to navigate and use all djay FX.
You can turn each FX on and off and use the βBeatβ knob in order to manipulate its intensity.
Hope this is helping.
