I’m wondering if the big iPad Pro is worth for use with Djay. I only have the small one, and it shows limited number of columns in the library view, and I’m missing the display of colour, grouping, etc. The extra columns/fields are not at all available on iOS, but am hoping that this will come in the near future. The bigger screen will probably make it possible to see more tags in the library …
Can someone with the big iPad Pro share some screenshots of Pro & HW mode with 2 & 4 decks, library view, tools panels in 2 & 4 decks mode?
So far there have been no different displays or additional options. But I would also welcome more options, even on the iPad 11”.
Hi @Kaloyan, currently djay on iPad looks the same on larger iPads as it does on smaller ones. Please see the screenshot below from my iPad Pro 13. I hope that helps!
it give more space for sure, but is the same proportionally.
The library should give more width for extra columns though. I really miss the color field not being displayed … and there’s room for it even on the smaller screen …
You’re welcome @Kaloyan. Additional columns are not currently supported on iOS devices.
