Im not sure how to add a drums kick/beat in the background of a song like the way you.dj allows you to do so. I’m a beginner so I’m not very sure, but I’ve looked in the effects but cant seem to find it. Thanks!
Hi Kunal Abichandani,
have you checked out the Sampler?
You can find the sampling section by clicking the 9 blue dots at the top left of djay Pro:
unfortunately this is not possible at the moment. Be assured that i added your request to our issue tracking system.
Cheers,Lukas E.
Hello Lukas,
Thanks for your answer. I have tried it out but that way I can only manually click the Drums Kick and it’ll play it just once. Is there any way to make it automatic so I dont have to keep clicking the button?
Regards.
