ENGLISH TRANSLATION: I have the program downloaded in English and I have not been able to change it to Spanish
ORIGINAL POST: Tengo el programado descargado en inglés y no de podido cambiarlo a español
Post in English please.
I believe that DJay Pro uses the default language set in your operating system, so if you have Windows set to Spanish then DJay Pro should display Spanish language.
@Slak_Jaw I’ve just searched the support area for ‘language’ and got no results.
Hi @Luis_Alberto_Campo_D, I double checked with the engineering team. The djay Pro language is automatically set to the same language as your Windows operating system.
Aw, that’s not fair. I said it first!
There you go @PKtheDJ!
