I try to connect Djay pro to simple midi controller DJ2GO and it doesn’t work
It works on the same time with Virtual DJ but not with Djay Pro!
Please give me advice how can I connect it ?
Hey there,
thank you for your mail.
Can you tell us which device you are using besides djay Pro?
Cheers,Lukas E.
Hey there,
thank you for your reply.
The Numark DJ2GO is natively supported by djay Pro, all you need to do is connecting the controller and accepting the midi mapping dialog window.
I play music on my AirMac.
This DJ2GO controller is working with VirtulaDJ automatically just after connecting cables. One minute later I try to use on Djay Pro but it doesn’t work.
I love Djey pro because there is many sources for playing music but I cant use such a simple DJ2GO controller.
please help.
I play music on APPLE MacBook Air 13’’.
