I have just got DJAY PRO AI and mixing mainly D&B.
The BPM is wrong is most of these tracks, I can see the double option, which helps for some of them. But not for others.
Can I change the tempo range of bpm analysis eg 165-175 BPM to make it more accurate
Where is the tap option to manually change bpm?
How do I manually move grid lines (on this video there is beats and grid section which I can’t seem to find in the version I am using
Are there any good videos on this topic?
Thanks for your help
