How to create a Playlist using iPad
As the title says, I would like to know how to create a playlist much like creating a Queue playlist…
Is there a way of doing this? I would like the tracks to be in the order that l set it up…
Thanks.
Hi @maurizio_T,
Thanks for posting your question!
In order to make a playlist in djay on iPad simply…
  1. Pick a track you want to add to a playlist
  2. Tap the button with the 3 dots inside it next to the track name
  3. Tap “Add to Playlist” and choose either a pre-made playlist or tap the plus button in the pop up window to create a new playlist or a new playlist folder.
Hope that helps. Have a wonderful day!
Thanks Nathaniel, much appreciated.
