I have been a Traktor user for years and now I want to go to djay/reloop.
So for this I need to convert my Traktor Cues and Loops to Serato. This because dJay seems to only pick up the Serato cues and converts them to djay cues and loops. But… this works only the first time a track is analyzed in djay.
I planned to do this conversion with the use of the nifty tool called DJCU (by ATGR.nl).
But now I imported some tracks accidentally that had not the good Serato Cues yet… and so I want to deleted these tracks out of the djay database in order to re-import them…
But now I do not see any possibility to delete the tracks out of the djay database… Yes only for those that are in the list with the djay-icon. But NOT those who are analyzed, but only those only under iTunes-icon.
Because I like to know how this works and in this case it’s only one for test purposes, but maybe in the future it can be 1000 tracks that id need to re-import after a batch conversion.
Hi @DJ_Big_Blender, sorry for the late reply. I just heard back from the engineering team:
Currently there is no way to completely remove all metadata for a track. However reimporting a track and re-analyzing a track should update the relevant info to the latest.
Thanks @Slak_Jaw.
Could you also confirm that re-importing a track also will help djay to re-scan the original Beatmarkers and Cues that are stored “in” the music-file (Serato-style) and convert them again to djay’s way of storing these loops and cues? Because that is the reason why I need to know.
You’re welcome @DJ_Big_Blender. Perhaps there is a 3rd party application that can completely remove all metadata from a track. I’m not sure if the Serato tags will be overwritten by djay 5 after import. I recommend you perform some tests with a small number of test tracks first to see what happens before importing your entire collection.
