How to Delete Start Cue
  • Device model: iPad Pro
  • Version of operating system: 17.3.1
  • Version of djay: 5.1.2
  • Hardware/controllers used: rebook buddy
Your question:
How do you turn off the white Start Cue? Shift/Cue doesn’t do it…
Hi @djqueenvic
Still there @Slak_Jaw
There is a difference between the Start Cue and Temporary Cue. The Temporary Cue cannot be deleted. It can only be moved. To move the Temporary Cue to a different location, simply pause the track and press the big Cue button next to Play on your controller or onscreen.
Oh God. Never noticed it before. Must have accidentally pressed something. Ps. Have you noticed any flickering screen reports today. Like shorting? @Slak_Jaw
No screen flickering reports today. It’s really starting to sound like there is an issue with your iPad. As suggested yesterday, I think it’s time to take it to an Apple Store for diagnostics.
Nightmare, but thanks as ever @Slak_Jaw over and out!
You’re welcome @djqueenvic. Good luck!
If you have the GUI set to Set / Cue rather than just Cue in the settings, the temporary (white) cue point can be deleted by long pressing the Set Button on iOS or iPadOS.
If you’re on a Mac left click and hold on the Set button.
This can only be done with the Set / Cue option though, if you have set it to just the Cue option, you can’t delete it.
:+1:t2:
I never use the temporary cue and have just midi mapped my cue button to a Hot Cue being that I have 3 out of the 4 bottom cue buttons are mapped to neural effects
Thanks so much @sooteee @maurizio_T
