How do I disable the swipe left to open the app on the iPad… it’s annoying af lol
On the iPad if i swipe left on the screen the djay app opens from the side and boots up… It’s annoying when I,m worrking on other stuff
Hi majik,
Are you referring to the App Switcher?
This is a system gesture which can not be switched off.
Cheers,Lukas E.
Is this only happening with djay or also with other applications?
Cheers,Lukas E.
