WeGo3 + djay2 (iPad AIR, iOS 8.1.2)
How to disable touch mode JOG?
On the controller such options no.
Please help!
I’m using ION controller and I need to disable the jog wheel too. I bump my finger unmeant frequently!
The problem is solved.
Put the off button of the sensor.
Any support for this yet?
unfortunately this is not possible while using the iOS version because the remapping of midi files is not supported.
Cheers,Lukas E.
