How to downgrade from 5.1.6
I am meeting too much scratch and bugs when using the stems. I don’t trust that version to play in a club. How to downgrade? Where can I download the previous versions?
Summary of the issue:
How to reproduce the issue:
Hi @VenetianDJ, you can use Time Machine on your Mac to rollback to a previous version of djay.
That is an unexpected answer, I don’t use Time Machine anymore for many reason.
I expected a link to download the previous version.
If not that is also fine to go back to Serato.
Understand that a DJ doesn’t like to have a crash in front of a crowd. If you can’t support them it is a question of time to stay only with baby djs.
Sorry @VenetianDJ, but we do not have the ability to provide previous versions of djay.
so that is perfect really smart from you
I just report a bug I have from the upgrade 5.3, impossible to map the deck Gain anymore. Using the keyboard shortcut is really not with enough precison. 1 more time I need to downgrade to 5.2.9 but you do not offer that necessary service.
Hi again @VenetianDJ, I answered your other post already, but I’ll summarize here again just in case. This is not a bug, but an intended change to how djay works with gain now. The gain controls via MIDI are still working, but they no longer control the auto-gain dial onscreen. To monitor you manual gain levels please refer to the position of the physical dial on your MIDI controller. Please refer to the other topic for more details. As for downgrading, you can achieve this via a Time Machine backup on you Mac. I hope that helps!
