Device model (e.g. 2020 iPad Air 4th Gen): MACBOOK PRO 2018
Version of operating system (e.g. macOS 14.4.1): OS SONOMA
Version of djay (e.g. 5.1.2): THE LATEST ONE
Hardware/controllers used (e.g. Reloop Mixon 8 Pro): REV 5
Your question:
HELLO THERE, I HAVE CHANGED LAPTOPS AND WANT TO TRANSFER THE CUSTOM SAMPLES I RECORDED ON THE OLD ONE TO THE NEW ONE; THANKS FOR YOUR HELP GUYS
With Apple doesn’t it give you option to transfer from one to another? With my Mac everything was changed over. If it’s just samples then you can get a usb stick and transfer that way. Probably quickest way as well.
Hi @MAZAL, navigate to the location where you stored your custom samples on your old laptop, copy them to iCloud or an external drive and move them to your new laptop. Then repeat the process for adding them to djay. For more info on adding your own samples, please refer to the linked FAQ below for macOS and iOS. Thanks!
Hi bro, thanks but the problem is that I do not have my original files, I just have the samples recorded into the djay sample bar and I intend to move them into the new laptop’s djay sample bar.
