On the latest DJay Pro for MacOS:
- Where is the export history to CSV for individual sessions or an entire year?
- How do I collapse the sessions on the history tab?
Hi @djsupe,
It turns out I could not find the history on the left panel because I use My Crates from Serato. Once I clicked My Collection, the history tab appeared.
The other part of my question was if there is a way to export an entire year or other timeframe instead of just per session
Ah okay. Glad you figured it out. You can only export 1 session at a time.
