I recently purchased the Hercules DJControl Mix. I will be using this with macOS & iOS. I would like to re-map the volume & filter/bass knobs to control the high & low. How can I do this?
@FlyersPh9 custom MIDI Mapping in djay is quite easy to do. Here’s the iOS guide. I’m pretty sure there’s a MacOS guide too if you Google it.
Hi @FlyersPh9,
Welcome, we’re happy to see you in the Community!
Not only do we have an FAQ on how to MIDI map a controller on iOS as @Slak_Jaw mentioned (thank you so much!), we have an FAQ on how to MIDI map a controller on macOS as well:
I hope this helps - Have a nice day!
