Hi, I’m new to Djay. I have Pro on my Win10 laptop and Djay 2 on my iPad.
I was looking to record pieces of a song and assign them to an FX pad. On my iPad it’s seems simple: I edit the pad, select ‘+’ and there I can assign either a pre-defined FX sound or I can pick one of the 2 record keys below in the menu to record from deck 1 or 2.
However, I don’t see the same functionality on my Win10 system. I can only assign pre-defined FX samples. There are no record buttons visible. Same on the Android version.
I can hardly believe that this isn’t possible in the Pro version that cost 4x more than the Djay 2 version. I would imagine that there shouldn’t be a big difference between Mac, Android or Win10…
So, perhaps I’m doing something wrong?
Any ideas?
