Would seem like simple thing, but cannot it out (iPad). If option doesn’t exist this is going to get messy.
I am not with Algoriddim Team, but I think I can help with that.
You cannot remove a song from a streaming playlist (at least not with Apple Music), as the native apps remain master (kind of protection), so you can only add songs (not remove) with the Djay App.
But of course, you still can remove songs from streaming playlists using the native Apps (example Apple Music).
EDIT : What I am saying here is wrong : This is how it works on the Mac App, not the iPad app. I don’t see how to delete from the iPad app indeed.
Thanks but I was referring to the playlist created within DJay.
Hi @N_C, what music source did you create the playlist in (ex. My Collection, Apple Music, Tidal, etc.)?
Within DJay Pro; My Collection.
Hi @N_C, to delete playlists created in My Collection, select the Edit text at the top right of the Library, then select the red circle to the left of the playlist you want to delete and finally select Delete at the right side of the playlist.
Ok, got it thanks. Is it possible to move playlists between folders?
You’re welcome @N_C. Yes, you can drag and drop from one My Collection playlist folder to another. Long press on the playlist then drag and hold it over another folder until it opens. Then you can drop it inside the new playlist.
Ahh, now that makes me happy. I note you can also move order. Great, this will help a lot. Thanks.
I have said it before - and I may keep saying it - if only the manual was kept updated - it is missing so much - things would be so much simpler.
You’re welcome @N_C. Happy to help
