Does anyone knows how to remove the content on the crate. When I select the crate icon from the left selection of icons, I see what appears to be playlist, not sure if they are smart or regular but what I want is to delete them.
Hi @Ls4life,
Do you know your device’s file path/folder where previous crates are stored? If so, have you tried deleting the contents of that file path/folder to remove it from djay?
Additionally, are you using djay Pro AI for macOS?
Looking forward to hearing back from you!
Hello!
I am using djay pro on my Mac and on a apple table. I am not certain of the
path where things are stored and I am sorry. I would belive deleting crates
should be accomplished from the software. Specifically if you are doing
things live. In any event, I am not sure where you need me to go to delete
this.
