How to remove song color in playlist
I did try to find answer, no luck, but forgive if Im repeating a topic.
Simple, would like to remove a color I assigned to some song in the playlist. Do not see a “Clear” button or an empty one. Tried clicking the same color button in case that would trigger removal. Alas not luck
This is an iTunes playlist… same issue in My Collections
Pressing the assigned colour again (on mac) clears it.
Edit: oops that didn’t work, I need to learn reading … but here it works anyway :slight_smile:
