Hi Djay’s does anyone know how to reorder the list of playlists? I dont mean reordering songs within a playlist but the playlist column to the left where all the playlist names are, is it possible to reorder that one?
Right now playlists are always sorted alphabetically - the only way to do a custom sort is to use a naming system that sorts them the way you need. For example, a 2 letter/number prefix (AA, AB or 00, 01 etc.)
You could use Folders to organize the playlists, but the sorting problem will remain (inside or outside of the Folders).
Hi @Paul_Bappoo,
Thank you for your post!
Additionally, many thanks to @Michael_Wisniewski for providing the solution to your inquiry!
Should you have any other questions feel free to reach back out to us!
