How save a Queue Playlist to recall it later in another time?
Hi @Lorenzo_Foligna, the Queue Playlist is automatically saved in djay. However, you may want to navigate to Settings>Library> and turn OFF Remove Songs From Queue When Played.
Ok, but if i want to clean it to creste another playlist, and in the future I want to recall the first one?
@Lorenzo_Foligna, I don’t have access to a Mac at the moment, but I can describe how to do this on iOS which should point you in the right direction.
- At the top of the Queue Playlist, select the drop down menu where is shows the number of songs in the playlist.
- From here, your should be able to Add All to Playlist…
- Simply add these to a new or existing playlist in My Collection.
I understand but i can’t find the drop down menu, please try to check if in MACOS version is same position as IOS version.
TKS a lot
Try switching to the Split Library view then select all songs in the Queue, then drag and drop from here to a new playlist in My Collection. Like I said, I don’t have access to a Mac, but this is what Split Library view looks like on Windows. This should help guide you in the right direction:
