How to scratch? what I mean is , whenever I try the “scratch crab” it doesnt sound right … Can someone tell me why.!!!
Hi Melvin,
Which djay version do you have? Which controller are you using? Did you enable “Crossfader Cutting Mode”?
vci 300 sounds like muddy water trying to scratch works fine for a second is that what yours sound like bre3z??
My djay version is the latest one, I did enable it but still not doing the effect! Sad…
Crossfader cutting mode enabled, and why my “jog pitch bend mode” doesn’t show up when my ipad is plugged into my ipad?
Plugged into my idj pro**
