How to Select a playlist for Automix Playlist?
It gives me 2 choices: none or a playlist that has been selected in the past. If I switch playlist it does switch as well.
thank you for your post. So the issue here is that not all your playlists are getting displayed in the Automix “select playlist” setting?
Are all your playlists being displayed correctly in the regular djay Pro media library?
Thank you for clarification.
