Hello,
What is the difference in filter resonance settings between high, mid, Low options ?
Hello,
Hi @Yan, this setting simply changes the amount of resonance with the main channel filters for each deck (the knobs above the channel faders). It’s best to just test the different settings to determine your personal preference. The difference in sound should be quite noticeable. For me, I like High resonance. I hope that helps!
Thanks mixing techno i prefer the smaller one > less distorsion .
You’re welcome @Yan. Sounds like you’ll want to set it to Low then.
