How to set Start and End Cue points with Reloop Mixon 4? Also how to delete?
These are the shortcuts that I use directly on my Mac keyboard:
Option+Q (Deck 1) or Option+P (Deck 2) – Set a Start Cue point
Option+T (Deck 1) or Option+Y (Deck 2) – Set an End Cue point
(pressing Q or P – Jump to Start)
(pressing T or Y – Jump to End)
Setting the Start and End Cue points is very important when we use Automix
Setting an End Point with the Mixon 4 is not possible with the default mapping.
But you can adjust the mapping via the midi learn feature to do so, if desired.
I know how to do it directly on Mac, but I don’t know how to do through Reloop Mixon 4.
Is it possible to set an End Cue point through the Mixon 4?
In case this be possible, it would be great to do it for both Djay Pro on Mac as on Ipad.
(I use Djay Pro on MAC and iPad connected to the Reloop Mixon 4)
