How to sort music by bpm in my playlists
YOUR QUESTION:
  1. how do I arrange the music in my downloaded playlists by bpm like I do in serato
Hi @djmarquee, you can sort by BPM by simply clicking on the BPM title at the top of the Library. If you press it a second time, the library will sort in the opposite order. Press a third time to return to the default sort order.
You can also rearrange the title according to your choice by hold and click the title then drag left or right
Yes, I’m aware of this functionality @Brown_bkp - thanks for sharing though.
