This has never happened before. Suddenly I’m in Hardware mode and cannot switch it off unless I disconnect controller. So things I need - while I get used to the controller at least - are not visible. Manual no use. It says you can toggle it on/off near waveform but I can’t find it. I can find status in Modes it has a checkmark next to it but when I tap it the window closes.
Think this as a default setting is very bad idea for anyone getting started with a controller.
Mixer Mode Internal
iPad Air 5
Reloop Buddy
Version 5.5.8
Paid subscription
Ok, got it. As I didn’t consciously switch hardware mode on, I thought it was automatic when a controller connected and I thought I was in Pro already (so hardware layered on top).
I appreciate the help, although it may seem obvious, it obviously wasn’t to me. I do though wish the manual/online help was more helpful, so I wouldn’t have to keep posting here so often (and maybe be able to fix things quicker).
The last time I DJed was 20 years ago. Things were so much simpler back then.
