Hello, I would like to be able to trigger all the FX features/functions there are in the Djay Pro 2 software. I cannot do this with my DDJ-SX https://www.pioneerdj.com/en/product/controller/archive/ddj-sx/black/overview/
There are so many more features and functions in the software. Which midi controller, like for instance the Midi Fighter https://www.midifighter.com/, would you recommend in order to complement the DDJ-SX and that can initiate the FX features/functions?
Cheers
Hi Mic,
Thanks for your feedback! Yes three effects total to one deck, and the software allows to choose bewteen very many effects (over 40 I believe) and one can choose mode, i.e. Pad, Instant and Manual. I imagine that it would be cool to be able to quickly change effects and mode with a midi controller. I might be totally in the blue here. Cheers
Not sure what you mean. The software only only allows you to assign 3 effects per deck.
Oh I see what you mean. Yes, that would be handy. It would require a lot of processor power though.
