I like using auto mix on my iPhone 6. When I use blue tooth in my car or wear blue tooth headphones, I can tap the “next track” button and the DJay 2 will start automix. So if you are close to a break in the track, you just tap the next button and the program will start mixing using sync. Is there a place on your iPhone that will let you do the same thing. I can’t find it.
Thanks. I actually never saw the button on my iPhone until you mentioned it. That’s what I’ve been looking for. You rock.
There should also be a “next” button on the lock screen if djay is running. Also, you can use the arrow buttons next to the crossfader in landscape mode.
