Is there a way to uncheck songs once it checks them as played? Either that or a way to pre-cue without loading the song into the deck?
Super and nothing has changed! Also not possible to preview song without loading into deck (during Automix). Brilliant!
Hi Kevin,
Which djay version do you have?
Then you can try to just clear the history. Click on the clock icon in the left library tab to access the history.
Oh, in this case, this is currently not possible. I’ll change your question into an “idea”.
djay for Mac. Version 4.2.1
Right. Except that clears all the check marks, even of songs that I want to still be marked as played.
