Can anyone please explain hoe to get the external headphones and microphone to work and can i use a combi microphone and headphones?
Thank You
Thank You
Please open djay’s Devices setup ( djay -> Preferences ) to select your device for output/mic.
What exactly happens after you select the mic in the Devices setup? Please tap the mic symbol in the bottom right corner of the djay window. What happens if you turn the mic on there?
Well, im using a external camera with a microphone inside and if i select it it doesn’t work HELP!!! please
Hope for a Awnser
Hope for a Awnser
