Hello everybody,
does somebody know how to use the Automix-function while using the Pioneer DDJ - SZ ???
Hello everybody,
Yes, switch automix on and put both of your faders up.
That does not happen when i use it. Latest version Djay Pro, macbook.
Hi Mirco,
you don’t need the SZ to be running in external mixer mode.
Could you send us your device settings?
When you are connecting the controller to your Mac are you accepting the Mapping dialog which is popping up?
But if I turn Automix on, Djay says I’ve to switch from extern to intern Mixer.
Which Version are you using? Mine is 1.2.1
Hi Lukas,
which device settings do you need?
