How to use ddj sb with ipad
Hi all, i want to use my ddj sb with my ipad…the iPad recognise it but it’s not supported by djay free, buying djay 2 or the 20€ version is there any chance it will work?
As RyuOnline said, the DDJ SB is not supported at the moment. You can use him with djay Pro for the Mac or if you want to get further information about iOS supported controllers follow this link:
https://www.algoriddim.com/hardware
Cheers,Lukas E.
The DDJ SB is unfortunately not supported by any version of djay on iOS.
I would be nice if algoriddim & pioneer added some of the newer larger controllers with djay 2/pro support.
Currently the DDJ ERGO & ERGO K is the largest Poineer Controller that works on iOS which works fine but is rather old now. The wego line is your only option for newer DDJ decks from pioneer.
